07-19-2023 10:00 PM - last edited on 07-21-2023 09:26 AM by CodeShepherd
Thank you for the reply.
Could you please help me? I am using CtrlX driveplus and have updated the firmware and the apps in the core to 1.20 due to which I am getting firmware inconsistant on the drive, I saw on the firmware compatability table in the drive data sheet that I would need AXS-V-0316 firmware, from the release 23.07 I got to know that I would need AXS-V-0402, I couldn't find the firmware in the collaboration room?
Currently I am running AXS-V-0314 on the drive and using gen 2 drives. I just have to check if I have double shield cables right, if not then do you recommend me to downgrade the core and also the apps?
Thank you in advance
07-21-2023 09:39 AM - edited 01-31-2024 07:58 AM
Publishing of the drive runtime 04Vxx is in work right now. Please get in direct contact with your sales or sales support person.
For best performance/stability on your application we recommend to use:
Update:
Please have a look to the current release notes for further information:
https://docs.automation.boschrexroth.com/doc/2893073323/software/latest/en/
12-13-2023 10:22 AM
Hi.
Is the Drive firmware 04V02 best for Core Runtime 1.20.5 also?
I saw that there was firmware 04V04 also released.
12-13-2023 11:03 AM
Please use versions like mentioned above.
Drive runtime 4V04 is related to ctrlX CORE system version 2.02.
01-31-2024 08:00 AM
Update:
I also added the update to the original answer above.
