Redundancy with ctrlX CORE -- EtherCAT network
arsz
Hello Community,
In one of my projects, I am planning to use two instances of ctrlX CORE to make my system redundant. I will read analogue sensor values via ctrlX IO (bus coupler and AI modules).
My question would be: Is there any solution to make the system redundant, as both ctrlX CORE could behave as EtherCAT master, and can read analogue sensor values simultaneously?
Aron Szekely
benstokess
@arszmcdvoice wrote:
Hello Community,
Aron Szekely
To achieve redundancy with two ctrlX CORE instances as EtherCAT masters, consider using a master-master setup or a shared communication protocol that allows both to read sensor values simultaneously without conflicts. Implementing a failover mechanism can help ensure continuous operation, where one master takes over if the other fails.
Sozu
Hallo,
thre is a solution available from our ctrlX World partner Gefaz. Look at the webside - PRODUKTE (gefaz.de)
Best regards
Sozu
