01-29-2023 07:54 PM
Hello, I have a big problem with the CtrlX,
since yesterday when I added elements in node-red, I could deploy but later, some elements were deleted by themselves from flows.
With a "review change" message appearing and telling me that a lot of items had been deleted,
Today, I tried to redeploy the backup I made of node-red.
the deployment went well but some time later I couldn't connect to the CtrlX anymore.
It restarts continuously, goes blue then green then red and restarts in a loop.
We are on a very urgent project and we need it up and running as soon as possible, can anyone help us?
Do you think the problem is because I loaded too many items in node-red? Is there a way to monitor memory?
I saw on other post that it was possible to do a factory reset from the sd card but I can't find the files on the site.
Thanks for your help,
Kevin.
01-29-2023 08:37 PM
It's in order, I can connect to the CtrlX again, I don't know if it had to do with node-red.
By disconnecting the XF10 port, the CtrlX was able to turn green.
I was able to connect via port address XF51.
I then changed the IP address of the XF10 port and since then I can reconnect.
Do you know where the problem could come from?
there was nothing else on the network with the same ip address
04-24-2023 09:25 AM
Have XF10 and XF51 been in the same subnet e.g. 192.168.1.x? This will lead to conflicts.
