04-19-2021 07:59 PM
Are there any recommended hardware solutions for bluethooth USB dongle extensions that work with the CtrlX CORE?
Application example could be a bluetooth connection to an IoT senor similar as it was used on the IoT gateway to the CISS sensor.
04-20-2021 08:21 AM
At the moment the USB functionality is quite limited please see this thread for more information.
01-03-2022 09:43 PM
What about bluetooth extension for IoT applications? The sugetsed thread only talks about Wifi dongles. What about bluetooth dongles? Any updates with RM 21.11?
01-13-2022 07:06 AM
Currently no Bluetooth-Dongle supported.
09-28-2022 03:58 PM
Is this still the case?
10-11-2022 07:14 AM - edited 10-11-2022 07:14 AM
@aFouraker Right now there are still no bluetooth dongles evaluated. Could you please send me a private message with your contact data and use case then we can have a talk about it.
13 hours ago
@CodeShepherd, is there any update regarding Bluetooth support by now?
11 hours ago
Die you check the mentioned topic "CtrlX Core - Wifi dongle connection"? There the current state is described/discussed.
