ctrlX influxdb grafana nodered
IIoT: Use ctrlX CORE as a monitoring platform using InfluxDB and Grafana
MauroRiboniMX
Contributor
The Goal
One of the most  requested IIoT feature of a machine is the capability to manage, store and visualize data. There are many ways to achieve this result, one of the best ways to achieve this goal is to combine three apps:
  • NodeRed: for connectivity
  • InfluxDB: data storage
  • Grafana: Simple and standard HMIs
Edit
It's now possible to use the official influxDB app with external memory support 📲. Scroll down to the end 🚀
Let's see together how we can setup a basic example.
ctrlX core InfluxDB and GrafanactrlX core InfluxDB and Grafana
Which data?
The data are coming usually from Ethecat, Opcua or third part devices here there is a brief list which will be updated:
Two ways
There are two possible configurations:
  1. InfluxDB 2.x + Grafana + NodeRed
  2. INfluxDB 1.8.3 + Grafana + NodeRed
There are not many differences, InfluxDB 2.0 it's an official ctrlX AUTOMATION app equipped with all the safety and platform features needed to setup reliable IIoT system. The only advantage in using InfluxDB 1.8.3 is the possibility to use the Grafana Auto-Complention features which can save some time. Chose the one you prefer considering that only the number 1 is the full supported by Rexroth.
Step 0 - Valid for both solutions
The first step in both cases is to setup NodeRed correctly how:
  1. install NodeRed
  2. connect ctrlX CORE to internet and check that the system clock is correctly set
  3. download the InfluxDB palette as shown in the picture
ctrlX node-red-contrib grafanactrlX node-red-contrib grafana
 If everything goes stright we should find these three new nodes on the left:
InfluxDB nodesInfluxDB nodes
Setup 1 - Productivity
What we need to install is:
  • InfluxDB 2.x
  • Grafana
In the end the sideboard should look like this:
ctrlx InfluxDB node-red grafanactrlx InfluxDB node-red grafana
Step 0 - Use an external memory (Optional)
When the influxDB (and thus memory) workload is high it is necessary to use an external memory to save influxDB data. Here there are the steps we need to follow:
  1. Navigate no setting ➡️ storage and locate youre device
  2. Format the device as an Ext4 device otherwise it won't work correctly in the long term.
  3. Mount it, it will be automatically mounted at boot
mount sd card ctrlxmount sd card ctrlx
 Now we need to go to the "Manage app data" menu, save the archive and edit the influxdb config file. W need to change the bold path and engine path to use our device. Once the file is saved we just need to upload the configuration on the device and update it.
archive modification memory externalarchive modification memory external
Here there is my file configuration example. usually mmcblk1p1 is for external microSD cards and sda1 stand for removable usb device.
Influxdb ctrlX external memoryInfluxdb ctrlX external memoryNOW REBOOT!!!
Step 1 - Setup influx
Go to the influx page clicking the icon on the left:
Welcome to InfluxDBWelcome to InfluxDB
 Setup the Initial use and the first Bucket, in this guide we just use boschrexroth as anything:
Setup initial userSetup initial user
 Go to Data API Token:
API TokensAPI Tokens
Just copy and keep secret the autogenerated token:
we're done here! Let's move forward!
Step 2 - Setup Node-Red
Load the example in NodeRed and open up the InfluxDB node!
Be sure to parametrize the node as follow:
In the server configuration is important to insert the token created before and insert the right URL:
But.. What does this example do? It's simple, basically creates a set o three random values that are then joined together to create a set of values loaded inside InfluxDB.
If we come back to InfluxDB and we select Explore, boschrexroth, Drive1 (the default measurement), all the fields and finally apply we can see the data flowing inside the database!! great no?
Data ExplorerData Explorer
Step 3 - Connect Grafana
We're almost done, we just need to connect Grafana. Nothing more simple! Lets do it!
Just open up Grafana, login with admin as user and admin as password then move to settings and then Data sources:
Data sourcesData sources
Select obviously InfluxDB then in the configuration Flux as query language.
ctrlX setup ctrlx grafana fluxctrlX setup ctrlx grafana flux
ctrlx setup grafana InfluxDBctrlx setup grafana InfluxDB
 The rest of the configuration is just like the NodeRed node! The click save and test!
ctrlX setup grafana InfluxDB tokenctrlX setup grafana InfluxDB token
 Ok almost done, create the first dashboard and then click the "add panel button":
ctrlx grafana new dashboardctrlx grafana new dashboard
Ok now the panel asks for a query don't go mad.. Work smart not Hard!!
InfluxDB ctrlx grafanaInfluxDB ctrlx grafana
Go back inside InfluxDB and open up the script editor, copy the query inside the panel and save!
ctrlx InfluxDB2 queryctrlx InfluxDB2 query
grafana ctrlx first dashboardgrafana ctrlx first dashboard
First Panel completed!!
Setup 2 - Alternative (not official)
  • InfluxDB 1.8.3
  • Grafana
In the end the sideboard looks like this:
simple ctrlx apps grafana noderedsimple ctrlx apps grafana nodered
By default InfluxDB 1.8.3 has no frontend so, there is no icon on the sidebar.
Step 1 - Setup influx and NodeRed
How? load up the NodeRed example and deploy it!
ctrlx InfluxDB 1.8.3ctrlx InfluxDB 1.8.3
What is happening? 1 si creating the database trough REST API 2 is setting up  a proper retention policy and 3 is creating random data!
Step 2 - Setup Grafana
Data sourcesData sourcesImportant! keep InfluxQL as Query language! and setup the url like this!
ctrlX setup grafana InfluxDBctrlX setup grafana InfluxDB
This setup has not security active, use the firewall app to protect InfluxDB! Insert drivedata as database (the example creates this automatically).
ctrlx grafana new dashboardctrlx grafana new dashboardNow we just need to select what we would like to see, it's far more easy in this case!
ctrlx grafana dashboardctrlx grafana dashboard
11 Comments
TN_X
Very interesting!
Is it possible to share with me the InfluxDB & Grafana App?
XuanLuo
It's very useful for me!
But I can't get the Grafana App. Could you please share it with me? Or just tell me how can I get it.
StefanH
Dear @XuanLuo ,
ctrlX IoT Dashboard will be available with the march release of ctrlX AUTOMATION. IoT Dashboard app is based on Grafana.
bschmidt
Thank you for this info! It is great to learn how to configure InfluxDB to use microSD for storage, as the on-board memory is limited and there is no setting in the InfluxDB web-UI for this.
CHH
Great guide!! thank you.
But when trying to access the InfluxDB 2.x web UI, i get the following error:
404 – Page not found. There is no page available under the path /influxdb
I installed the app on a virtual ctrlx.
Can you please advise me on how to solve this issue? thank you in advance.
MauroRiboniMX
Contributor
You have to use the last version of the ctrlX core software!!
chockalingam
Great How-To tutorial guide. Thank you!
Usalas
Hi All,
when we have the data base set up as external, the restore process does not work. i believe that the backup process does not include the SD card data and configuration that InfluxDB set up there. is this accurate? if so, how can we include those InfluxDB set up files from the SD card into the backup and be able to restore it to the SD card.
any suggestions?
stefanAT_ctrlX
I could not format my new SD-Card with the CORE (EXT4 format). I hade to format it before on my notebook to the exFAT Format and then I could format it in the ctrlX CORE with the EXT4 format. Runs well 👍.
bj_go
@MauroRiboniMX
Nice how to, helped me to get started with my first dashboard 👍
Setup 1 Step 0 is no longer optional with the newest InfluxDB-App. InfluxDB now needs external storage to work. But it's now easier to set it up. Step 1 to 3 (format and mount) stayed the same, but there was no need to edit any config file, it just worked out of the box.
Step 1 - Setup influx also changed a bit in UI and work flow (for example I got my API key directly after setting up my initial user) but it's pretty similar so I think no need to change that.
MauroRiboniMX
Contributor
@bj_go thanks for the feedback, i know that the guide is a lttle old but.. as stated still functional 😁. With the new updates and features i am going to make a new one 😁
Must Read
