I have a licensed Core for WebIQ but Installation fails , Is the app version 2.10 outdated ?
WebIQ Server App version 2.10 is based on Ubuntu core18. From ctrlX CORE system version 1.12 on only Ubuntu core20 is present on the system.
You will have to wait for the next release version of the WebIQ Server App that supports Ubuntu core20.
For testing purposes you could install the core18 app on the ctrlX CORE to make it work in the actual state.
1) When 2.12 is released ?
2) Do I need to step back to Unbutu Core 18 ?
3) If Yes , How ?
OK But if you look at my first screen shot it won't install - what is the trick to install on Core 20 ? Did I miss something ?
Sorry for the confusion. I do not mean that you should install the WebIQ based on core18 at the beginning but install the system app named core18 itself and afterwards it is possible to install WebIQ 2.10.
core18 and WebIQ2.10 installed
CodeSheperd you indicated that you would try to get more information. Is there more known about the 1.12 release for WebIQ?
I'm having the same issue.
Thanks!
It is working fine since installed core18 as mentionned.
@AndroidzZ The new version in of WebIQ is in internal beta testing phase at the moment.
