12-12-2022 03:51 PM - edited 12-12-2022 07:46 PM
I am using the WebIQ designer connected to the CtrlX Core. Whenever I try to add an alarm I get an error that says "Error adding alarm: Backend reported an error while processing API command "alarm.add": shmi:sqlite3pp:constraint:275:constraint failed"
I've tried different properties in the alarm but it always results in this error. Is there a way to fix this?
12-12-2022 07:46 PM
It looks like the Trigger Item is a required field. Filling this in fixes the issue. Hopefully they will make this alarm more clear to the actual problem in the future.
12-13-2022 09:30 AM
How would you want to trigger an alarm without specifying an item that triggers the alarm?
Please note the documentation that explains the alarm handling: https://docs.webiq.de/docs/webiq-designer-manual/#_define_an_alarm
We're working on improving the error messages, so these could definitely be better.
12-13-2022 04:17 PM
I was just wanting to lay out the alarms for future use once I have the variable in the code to bind them to. I've just made a spreadsheet instead and will fill them in as I go.
