07-24-2020 10:03 AM
i want to read and write some variables from the DataLayer of the CtrlX Core.
Does someone know, how the code in JavaScript has to be, or can I find helpfull examples anywhere?
Thank you!
07-27-2020 02:02 PM
In general you can use an standard JS library (XMLHttpRequest) that can do https requests to use the REST API of the system. Please refer to the documentation of "How to to use the REST API".
12-10-2020 11:17 AM
Hi valentinlamp
I created a webpage with js code based on the hello.webserver example from the SDK. The example (see attachment) reads several data from datalayer and the content of the webpage will be dynamically refreshed. Inside the *.js file the XMLHttpRequest object is used for the connection to the CORE/datalayer. The main parts inside the example project are the index.html and the /js/UserCode.js files.
04-11-2022 02:32 PM
@LunatiX , Thank you for your example! I am working on something similiar and this is very helpful. I was wondering if you had done anything similiar but using websockets instead of the RestAPI?
04-11-2022 03:53 PM
@aFouraker. Sorry, I don't have an example with websocket.
