Register multiple flatbuffer types in Data Layer
AlexStepanov
I want to use multiple different flatbuffers in my application, but I can't register more than one flatbuffer as a type in the data layer.
I extended the datalayer.register.node example to include a second flatbuffer (called sampleScheme2.fbs). Now when I start the application, I always see that registerType fails with the message "DL_INVALID_VALUE" for the second flatbuffer.
If I call registerType for sampleScheme2.fbs first, than sampleScheme.fbs returns "DL_INVALID_VALUE" when calling registerType.
Registering the nodes works without any problems.
Do I have to create a new data layer provider for each flatbuffer?
5 REPLIES 5
Re: Register multiple flatbuffer types in Data Layer
Sorry for the late reply.
Of course it is possible to register several flatbuffers in one app. I adapted the registernode example of the SDK for ctrlx AUTOMATION in version 1.10:
  1. Added new schema file "mysampleSchema.fbs:
    // IDL file for sample schema.
    namespace mysample.myschema;
    table InertialValue {    x:short;    y:short;    z:short;    a:short;}
    root_type InertialValue;​
  2. Extended CMakeLists.txt:
    # Flatbuffers
    set (FLATBUFFERS_FLATC_EXECUTABLE ${USER_DEPENDENCY_DIR}/bin/oss.flatbuffers/linux-gcc-x64/release/flatc)
    set (FLATBUFFERS_INCLUDE_DIR ${USER_DEPENDENCY_DIR}/include/oss.flatbuffers/oss.flatbuffers)
    include (${USER_DEPENDENCY_DIR}/cmake/oss.flatbuffers/FindFlatBuffers.cmake)
    set( FLATBUFFERS_FLATC_SCHEMA_EXTRA_ARGS "--gen-object-api")
    build_flatbuffers("sampleSchema.fbs" "" "registernodeflatbuffers" "${CMAKE_CURRENT_LIST_DIR}" "${CMAKE_CURRENT_LIST_DIR}" "${CMAKE_CURRENT_LIST_DIR}/bfbs" "")
    build_flatbuffers("mysampleSchema.fbs" "" "myregisternodeflatbuffers" "${CMAKE_CURRENT_LIST_DIR}" "${CMAKE_CURRENT_LIST_DIR}" "${CMAKE_CURRENT_LIST_DIR}/bfbs" "")
    # Define Executables to add from project files and their depending source files
    add_executable( ${TARGET_PROJECT_NAME}	${SOURCE_FILES_REGISTERNODE}  )
    add_dependencies(${TARGET_PROJECT_NAME} registernodeflatbuffers)
    add_dependencies(${TARGET_PROJECT_NAME} myregisternodeflatbuffers)
  3. Adapted main.cpp:
    #include "sampleSchema_generated.h"
    #include "mysampleSchema_generated.h"
    // Read function of metadata of an object. Function will be called whenever a node should be written.
      virtual void onMetadata(const std::string &address, const comm::datalayer::IProviderNode::ResponseCallback &callback) override  {
        flatbuffers::FlatBufferBuilder builder;
        flatbuffers::Offset<flatbuffers::Vector<flatbuffers::Offset<comm::datalayer::Reference>>> references;
        flatbuffers::Offset<flatbuffers::Vector<flatbuffers::Offset<comm::datalayer::Reference>>> references2;
        auto emptyString = builder.CreateString("This is a Description");
        if (address.compare("myData/myFlatbuffer") == 0)    {
          flatbuffers::Offset<comm::datalayer::Reference> vecReferences[] =      {
            comm::datalayer::CreateReferenceDirect(builder, "readType", "types/sampleSchema/inertialValue"),      };
          references = builder.CreateVectorOfSortedTables(vecReferences, 1);    }
        else if (address.compare("myData/myFlatbuffer2") == 0)    {
            comm::datalayer::CreateReferenceDirect(builder, "readType", "types/mysampleSchema/inertialValue"),      };
          references2 = builder.CreateVectorOfSortedTables(vecReferences, 1);      }
        // Set allowed operations
        comm::datalayer::AllowedOperationsBuilder allowedOperations(builder);
        allowedOperations.add_read(true);
        allowedOperations.add_write(false);
        allowedOperations.add_create(true);
        allowedOperations.add_delete_(false);
        auto operations = allowedOperations.Finish();
        // Create metadata
        comm::datalayer::MetadataBuilder metadata(builder);
        metadata.add_description(emptyString);
        metadata.add_descriptionUrl(emptyString);
        metadata.add_operations(operations);
          metadata.add_references(references);    }
          metadata.add_references(references2);    }
        auto metaFinished = metadata.Finish();
        builder.Finish(metaFinished);
    // Create dummy flatbuffer data
      flatbuffers::FlatBufferBuilder builder2;
      auto actInertialValue2 = mysample::myschema::CreateInertialValue(builder2, 33, -427, 911, 42);
      builder2.Finish(actInertialValue2);
      comm::datalayer::Variant myFlatbuffer2;
      myFlatbuffer2.shareFlatbuffers(builder2);
      // Register type of flatbuffer value
      // If running on SNAP environment, use $SNAP environment variable for register the bfbs
      std::string bfbsPath2 = getenv("SNAP") != nullptr ? getenv("SNAP") : "bfbs";
      bfbsPath2 += "/sampleSchema.bfbs";
      std::cout << bfbsPath2 << std::endl;
      result = myProvider->registerType("types/mysampleSchema/inertialValue", bfbsPath2);
      if(STATUS_FAILED(result))  {
        std::cout << "Register type 'types/mysampleSchema/inertialValue' failed with: " << result.toString() << std::endl;  }
      else  {
        std::cout << "Register type 'types/mysampleSchema/inertialValue' was successful!" << std::endl;  }
        // Register a node as flatbuffer value
      result = myProvider->registerNode("myData/myFlatbuffer2", new MyProviderNode(myFlatbuffer2));
        std::cout << "Register node 'myData/myFlatbuffer2' failed with: " << result.toString() << std::endl;  }
      else  {
        std::cout << "Register node 'myData/myFlatbuffer2' was successful!" << std::endl;  }
      // Unregister type and nodes
      myProvider->unregisterType("types/sampleSchema/inertialValue");
      myProvider->unregisterType("types/mysampleSchema/inertialValue");
  4. Run application:
David08
I am interested in making a very similar application to be able to send data to the PLC by Rest API in a single JSON file.
I've started to test the ResgisterNode example but VSCode is giving me an error because it can't find the "SampleSchema_generated.h" library.
How can I fix it, I have no experience with VSCode.
I'm using SDK 1.10 in a virtual machine with Ubuntu 18
Thanks in advance.
Tags (1)
The "xxx_generated.h" file will be generated by Cmake (code: step number 2 in previous post) just by following the build procedure.
  1. Open example in VSC
  2. Choose Cmake build option and wait for configuration to be finished:
  3. Build your project and the file will appear:
AlexStepanov
I still had problems, but I finally found the error!
strcat shouldn't be used with getenv, because the first arguments gets modified. See std::strcat - cppreference.com
Modifying the lines to something like this resolves the issues when running the app in a snap package:
std::string bfbsPath = getenv("SNAP") != nullptr ? getenv("SNAP") : "bfbs";
bfbsPath += "/sampleSchema.bfbs")
Thanks for mentioning we will check that and improve our example.
