Go server using Unix socket
jand
I'm trying to change the Go example to use a Unix socket as it is recommended. The main.go looks something like this (shortened):
import "github.com/gorilla/mux"
var router *mux.Router = mux.NewRouter()
func main() {
	router.HandleFunc("/my-snap/", func(w http.ResponseWriter, r *http.Request) {
		fmt.Fprintf(w, "Hello World")
	socketPath := path.Join(os.Getenv("SNAP_DATA"), "/package-run/my-snap/my-snap.web.sock")
	conn, err := net.Listen("unix", socketPath)
	if err != nil {
		log.Fatal("Could not listen on socket: ", err)
		return
	defer conn.Close()
	log.Println("Webserver started...")
	log.Fatal(http.Serve(conn, router))
And the snapcraft.yml like this (also shortened):
apps:
  my-server:
    command: ./bin/webserver
    daemon: simple
    restart-condition: always
    plugs: [network-bind]
parts:
  simple-webserver:
    source: webserver
    plugin: go
  configs:
    source: ./configs
    plugin: dump
    organize:
      'package-assets/*': package-assets/${SNAPCRAFT_PROJECT_NAME}/
slots:
  package-assets:
    interface: content
    content: package-assets
    source:
      read:
      - $SNAP/package-assets/${SNAPCRAFT_PROJECT_NAME}
  package-run:
    interface: content
    content: package-run
    source:
      write:
      - $SNAP_DATA/package-run/${SNAPCRAFT_PROJECT_NAME}
plugs:
  active-solution:
    interface: content
    content: solutions
    target: $SNAP_COMMON/solutions
However, when I look at the logbook, I see that the snap could not bind to the socket:
Could not listen on socket: listen unix /var/snap/my-snap/x1/package-run/my-snap/my-snap.web.sock: bind: permission denied
What am I missing here?
JohannesA
Hello jand,
i did not face the same issue, i try to build the same snap with a simple unix socket, and all worked fine.
You can find the test project in the attachments.
It also contains the snap for the virtual control.
Maybe you can share the difference with your project, thanks.
Regards Johannes
Okay, this took me a while to figure out, but the change that made my snap work was in the snapcraft.yaml file; adding the 5s restart delay.
apps:
  my-server:
    daemon: simple
    passthrough:
      restart-delay: 5s
The first log entry is still
Could not listen on socket: listen unix /var/snap/my-snap/x1/package-run/my-snap/my-snap.web.sock: bind: no such file or directory
but after the 5 second delay the webserver starts and binds to the Unix socket...
