06-18-2021 01:42 PM
I'm trying to access Datanodes published by my PLC_Application on the DataLayer with the C# Client.
I get the following Error every time I try accessing the node "plc/app/Application/sym/PLC_PRG/temperature". Sometimes the error appears after a few seconds, but sometimes the programm is crashing later, after a few successfull minutes.
The Application calls he ctrlX over network by a TCP-Client.
06-22-2021 03:06 PM - edited 06-22-2021 05:11 PM
EDIT: There is an known problem in older versions of the .NET Datalayer API less than 1.0.8.
In the next release of the SDK (1.10) coming up end of July as part of RM21.07 the latest version will be included. Please update to that version. If you need the update more urgent please write me an personal message with contact data from your side.
