01-25-2024 02:27 PM
Hello everyone,
I am new to the App Build Environment and installed it on my WSL. I built applications in Python and GoLang and run them on a virtual Core I created on ctrlX WORKS 1.20. However, in any (example) application involving the DataLayer, I am getting a similar kind of error (DL_INVALID_ADDRESS):
Unfortunately, I cannot figure out at this moment, what is wrong with the provided address.
Help is highly appreciated.
Best,
Karim
01-25-2024 02:40 PM
Hi Karim,
the client example you mentioned samples-python/datalayer-client tries to access data in the ctrlX Data Layer which gets provided by the example C++ sample samples-cpp/datalayer.provider.all-data.
So if you want to try out this example you need to install this provider example also. This is also mentioned in the README.md.
