12-04-2023 11:40 AM - edited 12-04-2023 11:41 AM
I've been encountering issues while starting my build environment, as it fails to boot properly. Despite following the instructions provided on this website , the system displays a notification indicating an error, as captured in the screenshot below. I've tried troubleshooting on my own, but I couldn't identify the root cause of the problem.
Has anyone else encountered a similar issue or can offer guidance on how to resolve this?
Thank you
Radwa
12-04-2023 11:58 AM
Hi Radwa,
Can you check on your PC, if your AppLocker is deactivated? - Maybe a active AppLocker can lead to some issues like this.
12-04-2023 01:01 PM
Hi Nick,
Thank you for the hint! it seems like it's currently active.
Do I have to select the "Configured" option and set it to "Off" , restart my computer and give it a try again?
Radwa
12-04-2023 01:34 PM
Hi Radwa,
yes I would recommend to turn of your AppLocker, restart the PC and create a new App Build Environment.
btw.: In case your PC is managed by Bosch-IT you can deactivate the AppLocker in the "IT Workplace Toolkit".
