12-06-2023 04:51 AM
I am developing a software tool using EAL Oscilloscope trending function, and successfully get the trending data with a HMC divice.
but after some time, the connection will be disconnected automatically, and the re-connect function is failed with the message "ping execution is failed"
If I close and restart the software, everything will be OK again.
hope someone can help me out. thanks
03-05-2024 11:22 AM
Hello Yaxccha,
could you solve your issue?
Is trending with Indraworks working without any issues?
For me it looks like your application is blocking the socket/connection and this is why you can not reconnect.
You can try to connect via Indraworks to verify if the connection is blocked. If so I would try to do a disconnect before trying to reconnect.
