Profinet error: RPC Aborted: 0x16C9A049
TN_X
Hi all,
Im currently using ctrlX (V 1.20) to connect with Camera of Keyence (CV-X400 series) via Profinet.
I tried to scan device by ctrlX but I got the error "RPC Aborted: 0x16C9A049".
When I change CV-X400 to ET200ST (Remote IO from siemens) then ctrlX can scan it.
After that I used S7-1200 PLC and tried to scan CV-X400 then it worked.
have you ever seen error "RPC Aborted: 0x16C9A049" in ctrlX when trying to communicate with other deivce via profinet before that you coud share?
Thanks
Is this still an issue or can you tell us a solution so topic can be closed?
TN_X
still in the the issue. But after that Customer replaced new Keyence's CPU which is also support profinet and already connected with ctrlX. Maybe its regarding hardware issue. Just confuse why Siemens PLC can connect directly to old Keyence's CPU while ctrlX can not. I cannot find the root cause till now!
