12-19-2023 02:06 PM
Hello ,
I have a ADFweb Ethercat slave device SW67E16 , But the ethercat master doesnt found it . attached the ESI file of the Ethercat to CANJ1939 converter .
Best Regards
Mesut
12-20-2023 07:05 AM
What is shown in ctrlX IO Engineering when you do an automatic scan of the fieldbus? Could you share your IO project here in the community or send it via a private message?
12-20-2023 09:08 AM - edited 12-20-2023 09:08 AM
Hello ,
in the meantime i had contact with adfweb , the dipswicth was not in a correct position , so the communication works now , now i need to handle the data byte per byte. thanks
