09-06-2023 08:57 AM
Hello together,
my topic is the following one. I do have an IV3-400CA camera system and I want to connect the camera system with a CtrlX Core X3. The connection should be IP based. I use a IP / TCP connection and the FTP (File Transmision Protocoll) [both camera und CtrlX are in one subnet]. Over the TCP connection I want to send JPEG pictures as well as preprocessed review about the pictures.
I do used Node Red app for the TCP connection, the PLC app is also an option. In Node Red I can connect to the IV3 camera with the TCP tools and I get a ping, but I don't get any data, with a debug module. I am not sure at with side of the connection the problem is.
If I want to test the connection from the camera GUI, the cammera isn't able to find the CtrlX.
BR RAK
09-14-2023 09:08 AM - edited 09-15-2023 08:43 AM
Moved to corresponding sub forum Communication.
10-05-2023 01:42 PM
with which commands and data you tried to receive data from the camera?
Do you tried with any other tool successfully before, any experience?
I'm doubting that plain TCP/IP is possible, because of the following text of the docu
"The IV/IV-G Series operates as an EtherNet/IP communication adaptor or a PROFINET communication I/O
device.
With EtherNet/IP communication or PROFINET communication, the control output signal and status result,
etc., can be input to the PLC as communication data."
10-18-2023 11:48 AM
@RAK Any news here or can this topic be closed?
