07-31-2023 01:29 PM
We want to use the DeviceBridge to collect Machine Data and send it to a MQTT-Broker. To connect to the broker, certificates are required.
As usual, three files are needed, provided to us as .pem:
- CA Certificate
- client certificate
- client key
We tried adding the certificates in the DeviceBridge Certificate Management via "Add PEM" button. So far, each try failed.
Are there any instructions on how to do this?
08-14-2023 09:49 PM
Kindly edit the Client Certificate content start copying from "Begin Certificate to End Certificate" to the respective Pem block in DeviceBridge
Similarly for the Client Key content
Choose PemWithKey or PemWithoutKey or EncryptionPassword as per the certificates offered by the MQTT Server
This should successfully get added to the DeviceBridge Certificate management provided the information added is correct
Hope this helps.
Thanks
Product Support
