DeviceBridge: Converter output string instead of integer
stefanAT_ctrlX
when we use a converter for a tag: e.g.     ((x-4000)*(150-(-20))/16000)+(-20)
then the output value after converting is a string ! Without using the CONVERTOR the datalayer-tag is a integer !
How can we solve this to get a integer.
(I don't want to use the business rule additional).
Regards,
Stefan
5 REPLIES 5
DvB_Support
Can we have the raw input range passed onto expression "x"
Product Support
dou you mean what is the raw format ?
It's directly from the datalayer/fieldbus:
DvB_Support
Hello Stefan,
Apologies.
our response got delayed due to business trips.
we will look into this concern and get back to you at the earliest
Product Support
DvB_Support
Hello Stefan,
Tried simulating the above scenario (9503 of type Int16 as raw input passed onto converter)
Output seems to be a double value and not a string by applying the converter logic to the tag
Kindly find the attached document (RawValue_Conversion performed step by step) and do let us know for any further clarifications
Product Support
Hello ! Thank you for the informations !
I just tried with the Json to Datalayer. Yes, in the datalayer WITH a converter comes a double value but in the result of the service monitoring is a STRING !
WITHOUT the converter the datalayer shows a int16 and the result in the service monitoring is a number not a string.
