Azure IoT Hub - Certificate
E_Stapel
Hello everyone,
is there an instruction for the connection between the devicebridge and the Azure IoT Hub? How it is possible to communicate with the devicebridge via https with the Azure IoT Hub and how do you create the certificate?
Thanks in advance.
DvB_Support
Hello E_Stapel,
we will soon be publishing the help documents / user manuals for all the available out of the box features within DeviceBridge app
To create a certificate to stream data to Azure IoT, Do you have the Pem and Key.Pem file along with Password ?
Thanks
Product Support
E_Stapel
Hello @DvB_Support ,
yes, we already have the files.
How long will it takes that the documents get published? It´s very importend to get help as soon as possible. Is it possible to get a contact, that we can connect the devicebridge with the Azure IoT Hub in a small meeting?
Thanks in advance.
DvB_Support
Hello E_Stapel,
Document / Manual publish might take a week or two for official release
Meanwhile i can assist you generate Pfx certificate / or generate and send you the Pfx to stream data to Azure IoT provided the artifacts (Cert.Pem, Key.Pem, Password) are shared to my email id Ramachandran.Praveen@in.bosch.com
Hope this helps.
Thanks
Product Support
