01-08-2024 11:08 AM
Is it possible to open different versions of the engineering using ctrlX WORKS?
01-02-2024 09:57 AM
ctrlX WORKS 2.4.1 allows to manage mutliple versions of ctrlX PLC- / ctrlX IO- and ctrlX DRIVE Engineering. If you start the software via the ctrlX WORKS UI please check the individual version of the software shown by the version in each button. If you want to change the version to be opened by the button please open the selection menue by clicking the "..." symbol and select the relevant version. See also ctrlX_WORKS_UI.png in the attachment!
