How do I import *.export file?
hideX
Hello
I'm trying "Fast time series data from ctrlX PLC to local InfluxDB",
download "daq.zip" file,
import this "daq.export" file to CtrlX PLC engineering.
But it can not be imported such like following message.
My current CtrlX PLC engineering information is here.
How do I import "daq.export" file?
bostroemc
It's possible to edit the *.export file using a text editor, replacing the existing CORE version information with the currently installed target version.
(In my case I have target version 1.20.60.0 installed.)
Since in this case the export file includes the device information, remember to import the resulting export file into the root node of the project.
@jacaré:  It might be helpful to include only the Application in the export file:
jacaré
I changed the *.zip-file according to @bostroemc comment. Please download again and try to import.
You need to first select "SPS-Logic" in your project and then "Project" -> "import".
Thanks for your information. I did it!
HmiGuide
Please mark the solution
