CXA_SocketComm empty TCP read buffer
K-Zanaty
Hello community,
I wanted to establish a TCP connection between PLC and another application.
However, I receive the messages but when I send a short message I can see that the buffer is not emptied and remaining characters from the longer string message persist. I tried to empty the string before receiving new data but this did not help
I hope you have a hint for me.
Best,
Karim
danielsimila
Hi Karim,
Which versions are you using on your system?
I use the following snippet to extract my recieved message with a ctrlX CORE @ version 1.20:
(* Receive some data *)
fbRecv(Execute:=TRUE, Socket:=udiSocket, ValueAdr:=ADR(strRecv), NoOfBytes:=SIZEOF(strRecv)-1);
IF fbRecv.Done=TRUE THEN
	(* Received some data *)
	strRecv := LEFT(strRecv, UDINT_TO_INT(fbRecv.NoOfRecBytes)); (* end of string marker *)
	fbRecv(Execute:=FALSE);
END_IF
JordiLaboria
Good morning
I am attaching a small manual of the communications in case it helps you.
Best Regards
Jordi Laboria
E-Mail: jordi.laboria@boschrexroth.es
DCET/SLF4-ES
Hello Jordi,
this helped me a lot, thank you!
Best,
Karim
this was a very valuable hint for me, thanks a lot!
