10-23-2023 12:19 PM - edited 10-23-2023 12:23 PM
Hello all,
We ran some tests with different ctrlC X3 Cores. Here we measured the boot-up time.
crtlX Core Runtime 1.20. 1 drive connected :
Total: 3 min and 1 sec.
For some customers this time is too long. Are there ways to speed up this action, or does the X7 start up faster? ?
Regards Johs Heijmink.
10-23-2023 11:16 PM
I confirm this feedback where more than 3 minutes (really more ...) is a problem for some customer!.
thanks.
10-24-2023 02:14 PM
I also did some tests but with less amount of apps (about 5) and the starting time on 1.20 firmware was above 2mins. As you said, we also have got some complains about long boot-up time and we are also interested in possible speeding-up this proccess...
10-31-2023 02:15 PM
We are following this topic internally but the standard bootup time from my experience currently is 2 - 2:30min. Please keep in mind that the ctrlX CORE is not only a PLC but a complete IPC that needs some time to boot up.
10-31-2023 03:31 PM
I know the ctrlX Core has some more than only a PLC. We did several timig test ( with several hardware and software) and about 3 minutes is the average. Still my question is open: will the X7 do the bootup faster?
01-03-2024 05:50 PM
I have also received complaints from potential customers about the boot-up time of the core X3. We also setup a system using 3 instancesof WebIQ runtimes, and found that the boot-up time was extended even further, closer to 5 minutes.
Whether this is really an issue in the field I sort of doubt, as highly automated equipment often takes long periods of time to recover. What I can say for sure is for a simple machine, taking 2-3 minutes to boot up and operate is definitely not ideal.
01-04-2024 06:25 AM
I also encountered the same problem, the customer Siemens (S7-1500) started quickly, and ctrlx took 3 minutes.
The customer is using 40 of our CTRLX and is very troubled by slow startup.
