I have connected core through ethernet cabel and light on core shows that it is fine but on ctrlx works I could not detect core.
ctrlX WORKS could not detect ctrlx core
Best reply by CodeShepherd
Please also have a look to this topic for access without correct network settings.
The easiest way is to check the settings of your network adapter in Windows. In standard there is DHCP activated and so the adapter will not have a valid IP when the ctrlX CORE is connected to it. You will need a 192.168.1.xxx (not 1).
