02-27-2023 12:12 PM
I have connected core through ethernet cabel and light on core shows that it is fine but on ctrlx works I could not detect core.
02-27-2023 12:55 PM - edited 04-24-2023 09:03 AM
Please also have a look to this topic for access without correct network settings.
The easiest way is to check the settings of your network adapter in Windows. In standard there is DHCP activated and so the adapter will not have a valid IP when the ctrlX CORE is connected to it. You will need a 192.168.1.xxx (not 1).
04-06-2023
07:55 AM
- last edited on
04-24-2023
09:03 AM
by
Hello kuldeepM
with the hint of CodeShepard were you able to establish a connetion to the ctrlX CORE?
Jochen
04-24-2023 09:08 AM
I am not sure cause I have tried many different ways and I don't know which one of them has worked.
