The app is currently not available
RainerFuchs
Hello
Last week the access to the controller worked perfectly
Now I geht this message
  • The "Service Mode" is currently active. Please switch to "Operation Mode" and try again
  • The app is currently being initialized. This may take a while, the page will refresh automatically.
How should I switch the mode, if I can't get online
Pinging the Controller ist possilbe.
What can I do?
Thank you
Contributor
Re: The app is currently not available
Could you please tel us, what the last steps were before shutting down?
Did you try to empty your browser cache and connect to the control again?
What is light pipe flash code? Probably you are stuck while booting somewhere.
RainerFuchs
I switched off the power supply friday afternoon.
Before I updated the system apps to the actual versions and installed all apps coming from the download folder
On friday everything works perfect
I emptied the cache, but it did not help
The LED is flashing blue most of the time
Sometimes green and sometimes red.
Thank you for your help
TheCodeCaptain
Hi RainerFuchs,
in the current version we have an issue when the memory is full the DeviceAdmin App doesn't start anymore which ends up in the situation you describe.
This can happen when you have to many apps on your control, even older versions of one app count.
Or if you have an app which writes on the disk and fills it up.
For the Version 1.8.x or older you have the following possibilities.
If you have a root user and ssh enabled connect with ssh and delete apps.
If not you can together with you partner from Bosch Rexroth image the control or send it to the Service.
