04-04-2023 05:12 PM
I'd like to modify CoDeSys VisuDialogs for a WebVisu application
Where to find the library?
In CoDeSys - help the path is: "\CODESYS\Projects\Visu\Dialogs" - but where to find it with ctrlX Works?
04-06-2023 04:11 PM
Hi, I do not understand your question. Do you want to patch the library VisuDialogs?
kind regards
04-06-2023 04:39 PM
I'd like to modify it.
For example: own colors, no limit fields, bigger keypad
The same for numpad:
Numpad is bigger than keypad.
And if it is an Integer value then there shouldn't be a "."
Instead of OK a green OK or a red X instead ESC....
In CoDeSys help there is a description but I don't find the original, uncompiled library.
04-24-2023 09:08 AM
We are currently checking this internally.
