09-10-2021 08:15 AM
Hello.
I try to make a first ctrlX configuration by ctrlX configurator, but I have trouble at the moment.
I search MS2N07, and add (press + bottom). Then MS2N07 changed MS2N05. I want to know why does it happened.
My target configuration is
MS2N03-D0BY-CMSG1-NNNNN-NN
MS2N07-B1BNN-CMSG1-NNNNN-NN
XCD2-W2323ARA-01AETT0ECNN-S03RSN2NNNN0NN
XNF1-1A-0100N-E0090-A-A4-NNNN-NN
RH2-023DBB-NN-003,0 x2
I selected by documentation. After that, I would like to check this is ok or not by system.
SOS cannot help it, because there is no data of XCD.
Please let me know how to check my configuration.
Thank you.
09-10-2021 10:26 AM
thank you the information. This is a bug and will be fixed in the next release. As a workaround: please start the product configurator of MSN05 and set the size to MSN07 via the product filter (see attached screenshot). This changes the default setting to the type MS2N07-B1BNN-CMSG1-NNNN-NN.
Best regards
