07-26-2023 04:58 PM
I implemented the RecipeManager integrated in CtrlX PLC Engineering.
To create new recipes I use the "CreateRecipe" method and then the "ReadAndSaveRecipeAs" method.
As I create new recipes, I can check the recipe counter ("GetRecipeCount" method) and the recipe list ("GetRecipeNames" method): everything updates correctly.
Also, by checking in the filesystem i.e. on "Manage App Data" the "/plc/run/linux-gcc-aarch64/data" folder I can verify that the files are being created.
The problem occurs if I restart CtrlX: after each restart the recipe counter is "1" and the recipe list includes only "the first" recipe created.
Can anyone help me figure out what I'm doing wrong?
07-31-2023 04:48 PM - edited 07-31-2023 05:05 PM
Could you please tell which version of the apps are used or add a system report, so we can get some insights to your system.
08-04-2023 12:10 PM
The PLC App used is version 1.20.1.
After verifying that the problem was not found on other hardware, I proceeded to perform Factory Reset and reinstall the applications.
The problem has been solved.
Thank you.
