06-14-2022 10:24 AM
any of you have experience in using Powerlink in Codesys, see link
https://www.codesys.com/products/codesys-fieldbus/industrial-ethernet/powerlink.html
Will it be possible to use this POWERLINK configurator to integrate a ctrlX Core device in a B&R enviroment ?
I am looking forward to your feedback
Best regards
06-15-2022 10:46 AM
The Powerlink Configurator in CODESYS will not help because it is made for CODESYS controls with integrated Powerlink stack.
Depending on which connectivity function is supported by the B&R controller and on the performance requirements there are the following options in ctrlX CORE for data exchange:
Additional options are planned for release milestone 22.07:
Due to the limited market relevance of Powerlink, a Powerlink implementation for ctrlX CORE is not planned.
