Hello
In the latest release there seems to be support for CODESYS webvisu. What is the steps needed to get webvisu up and running? Is the webserver part included in the PLC-snap?
Hello Borje,
yes, it is included, always.
You just need to create your page and then browse to you control on port 8080
You activate it here.
Hi
OK, does it also work with a virtualControl?
I use port forwarding, do I need to add 8080:8080 also in the list?
in a virutal control it is not yet included due to licensing.
Also for a real control you need to purchase a license from Codesys otherwise it runs only 2h in demo mode.
Fur second half of 2021 it is planned that ctrlX CORE customers can buy Codesys WebVisu license in ctrlX Store.
