I already checked the examples described in the forum.
/ctrlx-plc-ctxo5cm7/post/cxa-datalayer-how-to-write-a-flatbuffer-dlKyajQncuYip4N
But all examples described here, have methods, which returns a "pointer to real" or "pointer to string", ... so an easy datatype.
My task is, to read the pending diagnostic and in this case, the method returns an object "pointer to DiagnosticInformation from the table"
And I donĀ“t know, how to get access to this returned table. I have no chance to the information to the returned diagnostic string.
HereĀ“s my example:
Declaration:
PROGRAM PLC_PRG2
VAR
strMyInstancename : STRING := 'MyInstance';
bRead: BOOL;
bExecute: BOOL;
strNodePath: STRING(255) := 'diagnosis/get/actual/log';
fbDL_ReadNodeValue: DL_ReadNodeValue;
DataRead: CXA_Datalayer.DL_NodeValue;
fbDiagInfo : CXA_AutomationCore_fbs.common_log_diagnosis_fbs_DiagnosisIdentificationWithTimestamp;
pendingDiag: CXA_AutomationCore_fbs.common_log_diagnosis_fbs_DiagnosisIdentification;
strTimeStamp: STRING;
pendingDiag2: POINTER TO CXA_AutomationCore_fbs.common_log_diagnosis_fbs_DiagnosisIdentification;
END_VAR
Implementation:
IF bRead THEN
bRead := FALSE;
bExecute := TRUE;
END_IF
IF fbDL_ReadNodeValue.Done THEN
fbDiagInfo.getRootAsDiagnosisIdentificationWithTimestamp(data:= DataRead.GetData(), size:= DataRead.GetSize());
pendingDiag2 := fbDiagInfo.getDiagnosisIdentification();
pendingDiag := pendingDiag2^;
strTimeStamp := fbDiagInfo.getTimestamp();
bExecute := FALSE;
END_IF
fbDL_ReadNodeValue(
Execute:= bExecute, ClientId:= , NodeName:= strNodePath, NodeValue:= DataRead);
I get access to the Pointer, but I donĀ“t know, how to get access to special content of this table:
What can i do to see the actual diagnostic?
