Hi Community,
I am new to using CXA_SocketComm TCP.
I manage to established connection from ctrlX to a TCP device. However i did not receive feedback from the device after sending a string. (see attached)
Looking for advice.
Warmest regards,
Hi Community,
Looking for advice.
Warmest regards,
Hi CodeShepherd,
I am using IL_TCPConnectionAsync function block library.
Thank you for your tip we tried setting up TCP communication in Node-red, connection is established however when we attempt to send a string it did not send to the device and no feedback from the device.
We solved it by using Telnet communication in Node-red. It is unsure why it is behaving this way.
