CXA_Datalayer: How to create a remote device via PLC?
LunatiX
I would like to create a new remote device like the following:
(see docu: https://docs.automation.boschrexroth.com/doc/3584808565/configuration/latest/en/)
So I've to send/create a JSON/String to the node devices/remotes. Can I do that with the FB DL_CreateNode?
As you are sending an object you have to use DL_CreateNodeValue and create a fitting flatbuffer that can be sent. The flatbuffer description can be found in the metadata of node "devices/remote" --> "createType: types/datalayer/remoteconfig" --> "comm_datalayer_remote_ConfigItem". This flatbuffer is part of the CXA_AUTOMATIONCORE_FBS.
Sorry, but without a documentation or an example it's not possible for me to find a solution. There are so many fb's and methods available what makes it very complicated. See below:
start with fb DL_CreateNodeValue -> needs DL_NodeValue
-> DL_NodeValue has a lot of methods
See this post for another example and for your case see my working example below:
Declaration:
PROGRAM PROG_comm_datalayer_remote_ConfigItem
VAR
	fbConfigItem: CXA_AutomationCore_fbs.comm_datalayer_remote_ConfigItem; //Flatbuffer function out of CXA_Automationcore_fbs
	fbBuilder: flatbuffers.FlatBufferBuilder;     // Declare the flatbuffer builder out of CXA_Flatbuffers
	fbDL_CreateNodeValue: DL_CreateNodeValue; //Funktion block to write an flatbuffer out of CXA_Datalayer
	bExecute: BOOL;
	bDone: BOOL;
	bActive: BOOL;
	bError: BOOL;
	ErrorID: CXA_Datalayer.ERROR_CODE;
	ErrorIdent: CXA_Datalayer.ERROR_STRUCT;
	fbValueIn: CXA_Datalayer.DL_NodeValue;
	fbValueOut: CXA_Datalayer.DL_NodeValue;
	bStart_write: BOOL;
	udiName: UDINT;
	udiAddress: UDINT;
	strName: STRING := 'otherControl';
	strAddress: STRING := 'tcp://192.168.1.1:2069';
END_VAR
Implementation:
//////////////////Write values	/////////////////////////
IF bStart_write THEN
	fbBuilder(forceDefaults := TRUE); //Start flatbuffer builder and load with default values
	udiName := fbBuilder.createString(strName); //Create flatbuffer offset
	udiAddress := fbBuilder.createString(strAddress); //Create flatbuffer offset
	fbConfigItem.startConfigItem(fbBuilder); //Start flatbuffer function using the builder
	fbConfigItem.addName(udiName); //Add offset to the flatbuffer
	fbConfigItem.addAddress(udiAddress); //Add offset to the flatbuffer
	fbBuilder.finish(fbConfigItem.endConfigItem()); // Finish complete builder and closing the fbConfigItem
  	fbValueIn.SetFlatbuffer(fbBuilder); //Set flatbuffer out of the builder in the variable to be written
	bExecute := TRUE;
	bStart_write := FALSE;
END_IF
fbDL_CreateNodeValue(
	Execute:= bExecute,
	Done=> bDone,
	Active=> bActive,
	Error=> bError,
	ErrorID=> ErrorID,
	ErrorIdent=> ErrorIdent,
	ClientId:= ,
	NodeName:= 'devices/remotes', //Path of the node that should be written
	NodeValueIn:= fbValueIn,
	NodeValueOut:= fbValueOut);
