Unable to reset axis error
MC_ReadStatus.Errorstop :=true; At this time, it is not possible to reset through the reset function block,
if MC_ Reset.Execute=True Then
MC_ Reset will output error.
After power outage and restart, everything is normal.
Best reply by CodeShepherd
Could you add some more information?
  • What is the active command for "Axis_2" before error occurs?
  • Which error is occurring?
  • Could you switch on motion traces and create a system report after while the state you are showing is active? (Check out this post for how to do so)
View original
