I get an error on a motion axis when I disconnect from the Ethercat network the device which follow it in the nextwork
After I disconnect the 1003 device I could not runthe 2 drives connected to the network which are both in OP state.
I have 3 questions:
Why is the 1002 drive not working ?
Is it possible to run the devices which are ok in the network even when the last device is dsconnected ?
Is it possible to disable via PLC code or in some other way one on more Ethercat devices configured in the Ethercat network and eventualy disconnected?
Many Thanks,
Giuseppe
