How to Start/Stop a IDE script from PLC
Fred74
I would like to start and Stop the IDE scritp from the PLC. Which FB from which lib should I use.
MAny thanks for your help
Frédéric
Tags (1)
5 REPLIES 5
Re: How to Start/Stop a IDE script from PLC
You can use the CXA_PYTHON library:
Or use the REST API of the Data Layer with standart CXA_Datalayer
Fred74
What should I copy inside those 2 following inputs :
-Instance Name
- File Name
PS : I use your "DevelopR" example
Here a working example:
VAR
	fbIL_ScriptInstance: IL_ScriptInstance;
	StateInstance: CXA_PYTHON.INSTANCE_STATE;
	bEnableInstance: BOOL;
	bInOperationInstance: BOOL;
	bErrorInstance: BOOL;
	ErrorIDInstance: CXA_PYTHON.ERROR_CODE;
	ErrorIdentInstance: CXA_PYTHON.ERROR_STRUCT;
	strInstanceName: STRING := 'MyTestInstance'; //Name of script instance to be created
	bResetInstance: BOOL;
	bAbortScript: BOOL;
	fbIL_StartScriptFile: IL_StartScriptFile;
	bExecuteFile: BOOL;
	bDoneFile: BOOL;
	bActiveFile: BOOL;
	bErrorFile: BOOL;
	ErrorIDFile: CXA_PYTHON.ERROR_CODE;
	ErrorIdentFile: CXA_PYTHON.ERROR_STRUCT;
	strFilePath: STRING(255) := 'activeConfiguration/test.py'; //Path to the file to be executed e.g. root folder of the active configuration
	ParametersFile: ARRAY [0..9] OF STRING;
END_VAR
fbIL_ScriptInstance(
	Enable:= bEnableInstance,
	InOperation=> bInOperationInstance,
	Error=> bErrorInstance,
	ErrorID=> ErrorIDInstance,
	ErrorIdent=> ErrorIdentInstance,
	InstanceName:= strInstanceName,
	ResetInstance:= bResetInstance,
	AbortScript:= bAbortScript,
	State=> StateInstance);
fbIL_StartScriptFile(
	Execute:= bExecuteFile,
	Done=> bDoneFile,
	Active=> bActiveFile,
	Error=> bErrorFile,
	ErrorID=> ErrorIDFile,
	ErrorIdent=> ErrorIdentFile,
	FileName:= strFilePath,
	Parameters:= ParametersFile);
aFouraker
This is not very clearly explained in the IDE manual (R911410625, Edition 02, image below). When deploying to the target it would appear that the file path is
/skripts/Bosch/TIGER/application.py when in reality the path that works is /activeConfiguration/scripts/bosch/tiger/application.py
The path changed during development and is now always the active configuration for all our our apps. This has to be changed in the documentation thanks for mentioning.
