11-30-2023 12:04 PM
I0m trying to configure an axis with the Flexprofile functionality and I'm trying to insert the profile segments of my motion profile using the Cam Designer link I foound in the axis setting editing pages but I got this error
Could you help me to understand what I did wrong and how I can set a Flexprofile segmments table with my motion steps ?
Many Thanks
Giuseppe
11-30-2023 04:08 PM - edited 11-30-2023 04:15 PM
Hello Giuseppe,
it seems you don't have a license for the ctrlX Cam Designer, isn't it? For this you should add a license in the license manager of ctrlX WORKS.
Jens.
12-01-2023 09:32 AM
OK Thanks, I'll check if the license is missing.
However is it possible to create a Flexprofile segmnets profile without using the Cam Design Tool ad we did on MLC ? Is there any place where I can set the different profile segmets with their motion law in the CtrlX datalayer for example or using a PLC function block ?
Many Thanks
Giuseppe
12-01-2023 10:28 AM
ctrlX Cam Designer is not only one way of entering flex profiles.
12-04-2023 09:48 AM
I'm trying to install my Cam Designer license on the CtrlX Works 2.2 versione I've installed on my PC but when I try to access the licemse page I get this error:
Doy you have any advice about how to avoid it and install my Cam Designer lincense ?
Many Thanks
Giuseppe
12-05-2023 07:16 AM - last edited 3 weeks ago
It seems that your trusted storage is corrupted/invalid. Please send me your contact data via a private message to investigate further.
