Error Diagnosis codes have not been set
AndroidzZ
I get the error: Diagnosis codes have not been set
Not on a specific moment but on random moment in my application.  Error code 090f2040  oc560270
Im not able to resolve this error with a normal reset. i have to reset my application or power ON/OFF the CORE.
Sometime the error dont occour for some time and then when it occours it occours often.
System report and logbook file in the attachment.
Tags (3)
5 REPLIES 5
Jochen_Mueller
Re: Error Diagnosis codes have not been set
Hello AndroidzZ
sorry for the late answer.
We checked the logs and see that this error is comming from the motion. To find the source we need some more information. So please activate the Motion-Trace, wait for the error, save the logs again (see screenshots) and send it to us.
Jochen
AndroidzZ
The application is currently being upgraded. When possible I will send the motion trace.
The error is an motion internal one and will be solved in the RM21.07 (v1.10). Also there the diagnosis system will provide more information.
LZT
I have the same problem when i used the ML_AxsSetAbsPos function. the error(091F2040 system error,0C560270 internal error occurred)
 is occured when i enable the function. i must disable the function otherwise the error cann't be reset.
I used v1.12,Is there any solution?
In the next days there will be an new patch of the motion app 1.12.7 with some bug fixes to that problem.
