Hello everyone,
I am trying to compile the PLC-Template for Handling.
It seems I am missing a CXA_MOTION_INTERFACE.
Could not open library: CXA_MOTION_INTERFACE. Reason: The Library CXA MOTION INTERFACE, 1.12.2.3 has not been installed to the system.
CTRLX WORK version 0112.9 / PLC-Template for Handling / Could not open library CXA_MOTION_INTERFACE
reproduced your described behaviour. And had a look in the docu available unter:
https://developer.community.boschrexroth.com/t5/Store-and-How-to/Template-for-cartesian-handling-sys...
It is mentioned to modify the CXA_MotionInterface lib to 1.12.1.0. Doing so made the template project compile.
Please try:
Did it work for you?
Bye
Worked for me.
