Switch Node on Node-RED doesn't has add rule button
shahrulamri
Hallo, my customer has been complain about their ctrlX Node-RED 'switch node' does not has an add rule button. How can I help them to get the add rule button, my colleague alredy asked about the consent on node-red community. Hopefully I can get the solution at here asap. Here I share the picture for a reference:
1. switch-node-issue-1
- customer switch node
2. switch-node-issue-2
- my switch node which has add rule button
3. switch-node-issue-3
- the node inside a function pallete
MauroRiboniMX
Contributor
Explain me what you want to do, Are you referring to a command which is a switch or the switch command?
Which kind of rule?
Mauro 😁
nickH
Hi @shahrulamri
I just tested the switch node on my ctrlX CORE and I can add new rules. See my screenshot:
Is that what you are missing?
Yes, the '+' button is what I'm missing
Tery to use a different browser 😄 and use the last app version.
