03-18-2024 07:47 AM - edited 03-18-2024 10:17 AM
I have problem data aquisition from Omron PLC (CP1L) with node-red. I used FINS protocol and pallete. When I try to read the data there is timeout in debug. Then I tried it in node-red at virtual control and . There is no problem communication (It can read the data).
I don't know what caused this problem. Can someone help me?
Thank you in advance.
03-20-2024 09:40 AM
As the Node-RED pallete is a third party product our support could be quite limited.
Could you add some information about the topology when using ctrlX COREvirtual or a real one? As one is working it sounds like a network connection problem. Feel free to have a look to the how to "Communicate between a ctrlX COREvirtual and other applications".
03-25-2024 04:46 PM
Hello @Ihsanf ,
I once tried it and was fine, how did u install the node? Didi u install it directly on the core x3 or you restored the configuration from a visrtual core?
