Node-RED EPERM error when deploying
NielsWe
when deploying changes in Node-RED 1.10.0 or 1.8.4 I get the following EPERM error:
Search flows
Flow
"d9447549.a50b28"
Deploy failed:
"code":"EPERM",
"message":"EPERM: operation not permitted, copyfile '/var/snap/ctrlx-node-red/109/solutions/activeConfiguration/node-RED/flows.json' -> '/var/snap/ctrlx-node-red/109/solutions/activeConfiguration/node-RED/.flows.json.backup'"
There is no error with the initial deployment or when deleting flows.json from the Configurations. So the copy/rename seems to produce this error. I am logged in with full permissions.
I dont have any issues on a second ctrlX CORE with the same Versions installed.
Any clues?
5 REPLIES 5
Re: Node-RED EPERM error when deploying
There were some write problems in the older version of snapd. Please use at least the RM21.07 version (2.51.1). Afterwards:
  1. Export all flows (Flow -> Export -> Alle Flows)
  2. Create a new configuration and activate it (Manage app data)
  3. Import all flows
  4. Deploy all flows
NielsWe
I have installed all apps as delivered with RM 21.07.2.
But the error persists as described.
Did you try using a "new" empty configuration, like described above?
NielsWe
Yes. I tested a new clean configuration.
I will compare this devices setup with a second device (that is working) tomorrow.
