Get directory path from PC
Hi all,
currently im using "Directory" and "File Status" nodes to find out the directory path from my PC. You can refer as below
This is done by node-red installed in my PC. My question is how can I get this directory path when using node-red installed in ctrlX core?
If you know to to access to PC's directory by using ctrlX core please share with me.
Many thanks.
Regards!
Best reply by CodeShepherd
Which palette (including the directory and file status node) are you using for tests of your PC based Node-RED?
In case of installed Node-RED app on a ctrlX CORE you can use e.g. ftp or smb extensions for accessing files on the network e.g. on your PC.
View original
