In the documentation for the S20-SGI-2 Module the out process data for Tare, Zero Point and Adjusment are listed but the explanation is unclear.
Further in the document, a description is given on how to set up the device using the PDI channel but it is unclear if this method can also be accomplished by the bits of the same name. See the example below
The question is
1) Must I use the PDI channel to intiaite the Zero-point, tare and adjustment or can these be accomplished with the output control word and
2) what is the difference between the "tare" and finding the "zero-point?"
