Winstudio OPC UA with 4K vars
Hello
Hardware
PR4200.1-2B1-AA-000-NN-C1-NNNNNNNNNNNN-H with Indraworks 15v16.3 and winstudio Runtime 4K with COM
Corex X3, Apps: Systemapps 1.20, PLC 1.20, OPCUAServer 1.20 and more
I feel that the OPC communication is quite unstable. It takes multiple restarts of Winstudio Runtimeapp before all vars is updating/communicating with Server. After a while it seems that some vars stops to communicate.
Using 3,5k vars in 17 driversheets.
Varcount i sheets: Min:10 Max:400
Publishrates: Min:200ms Max:1s
No Sequrity
Winstudio settings
Communication - UPCUA - Serverconfiguration - Advanced
Setting of Driversheets
PLC symbolefile settings
The symbolfile is quite big. Using attributes to make the symbolefile. I have lots of vars that i can remove from the Symbolfile.
OPC server app 1.20 settings
CPULoad on core2 (Where the server runs) 70-80%.
In lack of knowledge how OPC-UA works i need help with these settings to accoplish a good communication between HMI and PLC. Especially Server settings.
Thank you.
*Update: Added Logbook
Best reply by Peter_B
The parameters on the WinStudio side seems to be ok. It is a good idea just to trace one of the driver sheets. You can use therefore an Integer tag for Status and a string Tag for the message. Every value (status tag) not equal 1 is an error message.
in addition to that you should trace the communication with remote Logwin.
Peter
View original
Diagnostic_Log_2023-06-05_12-32-05.csv
395.03KB
1 reply
