05-07-2020 08:01 AM
Till now it was not enough that the resolution has been changed after first boot up (from 0.001 -> 0.1) and it was problem when you forget to do that.
05-07-2020 01:10 PM
No, it should have been good enough to just shortly go to OM mode and back again to PM. Then the new scaling should have been taken over. A reboot is not necessary. With the new CM mode this now might get more transparent. 😎
regards,
Stefan
