finding in the planning manual that it is possible to operated on a 1x230V supply voltage with the ctrlX Drive, so fare so good
But I have tried to find out what requirements are need, thinking of filters, max cable lenghts etc ?
Also what is the continous and maximum current output ? Still the same, e.g. 6/23 A for the XCS0023 drives ?
Trying to use the configurator doestnt help, since it only shows 3x200-500V supply voltage but not possible to select 1x230V
Servodude
Please refer to the actual documentation
https://www.boschrexroth.com/documents/12605/25199765/R911386579_09.pdf/6806ba70-af0a-cf57-880c-9e3d...
The rated power is reduced:
Sorry, I mis that one. I was looking in the mains voltage and DC bus tables.
But using the search function I can not find the corresponding netfilter, only the filter for the 3 phase mains voltage.
New to me but which netfilter should I use for 1-phase mains voltage on a XCS2-W0023 drive, is the NFE02 fpr the HCS01 drive usable ?
In total 8 drives with total 80 m motorcable, total continues power approx. 1 kW
Servodude
