Can I specify the EtherCAT address when use double axis and one of axis has been broken?
Hello  CtrlXDrive Team
I have a question,In my project I used double Axis CtrlxDrive,Now one of the CtrlXDrive Axis  has been broken.I want to know if it possible to specify the EtherCAT address?
When I deleted one of the CtrlXIO configuration,the address will Automatic sorting.
I don't want to delete one of the broken axis configuration ,I just want to use Parking Axis funtion?But it is not possible.
How should I do?
Best reply by CodeShepherd
At the moment the EtherCat address is always auto incremented, so it will be resorted when changing the topology in ctrlX IO Engineering.
There will be a new feature in the next version 1.20 that drives can be identified via their names instead of logical address.
I did some test some time ago and used successfully parking axis mode of the ctrlX DRIVE. What means it is not working on your side?
View original
